my trunk opens on its own!!
hello i own a nissan qasqhai 2011 model j10 1.5 dci diesel.i have a problem with my trunk.it opens on its own!usually when i unlock my car i press the trunk button and does nothing,then when i switch my lights on the button works great!also sometimes when the trunk button is not working i switch lights on and off as soon as i switch lights off trunk pops out!i think but im not sure in rainy days the problem comes more often.anyone know whats the problem?
thank you.
thank you.
Welcome to the forum mate.
Sounds like you have a short in the wiring somewhere.
Have you done any tests to see when your trunk latch gets a signal?
Change the battery inn the key Fob, may help.
or trade it in for a toyota. :) :) :)
Sounds like damp getting into one of the wiring harness connectors to me.
X type Jag estate tailgates used to have a similar problem with the opening glass section.
