my wall outlet's buttons broke off | on ElectriciansForums
Discuss my wall outlet's buttons broke off in the DIY Electrical Advice area at ElectriciansForums.net
CCK
my wall outlet's buttons broke off and got a bit confused as all the wires are brown .what are these 2 wires for ? Thank you
  • [ElectriciansForums.net] my wall outlet's buttons broke off
Thats a Hager 3 gang rocker switch.
Each is a single pole, 2-way switch (in UK terminology).
2 way switches are normally used where there is another light switch controlling the same light as this one. Is that what you have?
This is the sort of arrangement for your switches, with the C, L1, and L2 marked on the switch terminals
With light switches, all connected wires are 'live' - not sure what you mean by "all the wires are brown" - I can see a blue one 🤣!
If it's a 2-way (UK) circuit, there needs to be a wire in the 'C' terminal of the right hand switch for it to work!
Reply to my wall outlet's buttons broke off in the DIY Electrical Advice area at ElectriciansForums.net
That worked!!! Thanks again for all the help and responding so quickly. Really appreciate it!!!
I painted a bathroom and must’ve gotten paint inside an outlet because it’s not working. Went to the fuse box cut it off and changed out the...
