Mystery light failure | Page 2 | on ElectriciansForums
Discuss Mystery light failure in the Lighting Forum area at ElectriciansForums.net
Thanks everybody. Turned out it was the light switch and I didn't need to touch the lamp holder so I'm going back to Screwfix for a refund
when you say it was the switch, you changed it before the problem or it had a loose wire etc ??
Had a look inside the switch. The live wire broke away from the switch as soon as I moved it. So I thought that was the problem and I stripped back the wire and reattached it. However it still wasn't working. Luckily I brought a spare light switch and replaced the old one... and voila it worked
Reply to Mystery light failure in the Lighting Forum area at ElectriciansForums.net
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
Thanks very much - again for your input. It is a moulded-on plug. The first thing I did was change the fuse - which looked, and no doubt (now)...
