B
bigbaddave
As above... Possible?
Discuss N-e fault on non RCD side of db tripping RCD??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I was thinking exactly the same thing to be honest.Hi,
I am curious, could someone please explain how a N-E fault confined to the non RCD side of a board could trip the RCD, given that N-E is joined at the TX, or cutout...
Out of interest, did you have a short N-E or low insulation resistance N-E when you had this?N-E faults can cause some weird effects. i had one where a N-E fault on 1 side of a new dual RCD CU stopped both RCDs from tripping, even with the test buttons, but when a load was applied to either side, both RCDs tripped.
Reply to N-e fault on non RCD side of db tripping RCD??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
