Name these connectors | on ElectriciansForums
Discuss Name these connectors in the Electrical Tools and Products area at ElectriciansForums.net
TheJay
United Kingdom
Hello there, I just wondered what these connector blocks are called and where I could get more of them? Do I just need a regular modular rachet crimp tool?
  • [ElectriciansForums.net] Name these connectors
Wago`s...few different types available, the ones in your photos are 773 series, Srewfix always keep a good stock.
Just push to fit, no crimping required
They are something similar to a wago, but made by someone else, probably ideal but could be hellerman etc.
You can buy them from your wholesalers
The ones in your picture are by Hellerman Tyton and called Helacon. In general terms they are called push in wire connectors. Or pushwire connectors for ones by wago
Your picture shows HECP-4 at the front and HECP-2 at the back.
As has been said above many makes available.
I like to use several makes myself, Helllerman Tyton do a 4 gang push it thats horizontal and not all square, and Ideal do a three way push in, and Wago do many others, I keep a stock of all different types as sometimes you might be really pushed for space and need a different shape connector, still say a 4 way, but horizontal nor bunched as it were.
Reply to Name these connectors in the Electrical Tools and Products area at ElectriciansForums.net
Hello I am going to use this pin connector to power a HDPLEX HIFI DC-ATX 500 watt power supply. The power supply has a 8 pin dc input connector...
The repair kit is actually sold by WAGO for that specific purpose (in the wall repair). I had wondered myself about shrinking individually first...
