Evening Folks,
I use the above forms on laptop. Generally write roughly then type up at home.
I did download the latest Adobe reader/viewer/thingymabob, but when you go to save the cert you cannot rename it or do 'save as'. It will only save as the original Adobe file name. I tried this on android, and it was a little while ago, but wandering if saving under a different name is possible using iOS or indeed even android now. Basically want to start using a tablet for forms. I know there are other cert packages out there but I quite like the NAPIT ones.
Thanks, Neil
Thanks, Neil
