nappit assesment | on ElectriciansForums
Discuss nappit assesment in the Business Related area at ElectriciansForums.net
J
jimmylaud
hi im currently in the process of getting registered with nappit and was wondering if anyone knows what sort of assesment you get when you join thanks in advance
they will check your paperwork, insurances, certificates for test equipment, look at certificate issued, qualifications. then take a look at a job you have done, ask some questions on testing etc
also
They might also try to extract your teeth with a pair of pliers and no anaesthetic :D
Good luck
If you know you are competent, you will be ok
Reply to nappit assesment in the Business Related area at ElectriciansForums.net
The second page of this thread might be of interest: https://www.electriciansforums.net/threads/napit-ist-assessment.189450/page-2 I'm not a...
Yep They try to sell, sell, sell At the last asessment I told the asessor that I used SELECT to update my regs and inspection and testing, on...
