hav u ever had a nearly big mistake, i was making off 95mm 4c swa inn2 a main switch,everything was going splendidly when,i cut the last 1 slightly shorter than i suppose 2 .Panic...then after alot of swearing...i noticed the panel the switch was mounted on had moved slighlty of its fixing screws,jus about 4mm,after adjustin in2 its position the cable was ok 2 connect,relief at last,heartbeat bac 2 normal.
