Need a multimeter for tool bag | on ElectriciansForums
Discuss Need a multimeter for tool bag in the Electrical Tools and Products area at ElectriciansForums.net
P
pauk
Hello, all
I want to buy a multimeter for my father's tool bag, is there anyone of you owned one smaller than this [NOPARSE]www.amazon.co.uk/Digital-Multimeter-Tester/dp/B00EYYJQOO/[/NOPARSE] Or any other suggestion? Thanks in advance.
I do own a few cheap multimeters, and the one that Pete said is one of my face (i think because of the case) tho it dose have some mm burn marks BUT IT STILL LIVES..
LAP MAS830B Digital Multimeter 600V | Multimeters | Screwfix.com
They are pritty standard chip they are working off, the ones i buy cheap from china (because Test Leads in the UK can be as dear as the Chinese Multimeter and leads [tho some of the leads from china and machine are brittle])
I use this one and find it a good bit of kit.
Megger AVO410 Digital Multimeter - AVO 410 Multi Meter from Megger
[ElectriciansForums.net] Need a multimeter for tool bag
^ Double cheer for above. I have used the 410 for a couple of years now,and any qualms i had,due to its' slight bulk,were forgotten,as its' features proved invaluable.
I have only just replaced the internal 9v battery,this very afternoon. The capacitance range has also been handy.
In my Snap-on FOD carry box,i have a Robin Multi-Test.It has the usual ranges,and data hold/range change facility...but a real handy,AC/DC fork type current clamp. It is small,has fixed leads,which stow in the edges of its' rubber jacket.
It is now marketed under a different title,i believe,but i have carried it for the last 20 years,and,bless it,has earned its' weight in gold....probably literally!
Reply to Need a multimeter for tool bag in the Electrical Tools and Products area at ElectriciansForums.net
I use this one, copy this into a search engine: 200EP Tone Generator Kit High Accuracy Cable Toner Detector Finder Tester with Inductive...
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
