Need a sanity check on a 3-way smart switch installation. | on ElectriciansForums
Discuss Need a sanity check on a 3-way smart switch installation. in the UK Electrical Forum area at ElectriciansForums.net
relytgerg
Hi. I'm a newbie in this forum. I'm a homeowner who's done plenty of simple lighting, outlets, etc. even including a couple of circuit breakers. I've never done a 3-way switch before though, let alone a 3-way smart switch. I've been doing my homework, but would still like a sanity check. The current wiring on very old three way switches looks like this:
[ElectriciansForums.net] Need a sanity check on a 3-way smart switch installation.
I am planning to install a 3-way smart switch with WiFi capability and a dimmer. It's this one from GE. It will go in the primary (SW1) position. For the add-on switch, I'll be using this from GE in the SW2 position. Per this video I will be wiring things as follows:
This seems to solve the problem of the missing ground wire in the older wiring on the secondary switch and still meet the requirements of the wiring for the new smart switches.
As it says in the subject line, I'd appreciate a sanity check on this.
Thanks.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Need a sanity check on a 3-way smart switch installation. in the UK Electrical Forum area at ElectriciansForums.net
Yes I understand the setup now. Sorry about my confusing first post 🫢 It might be worth buying the Livolo switches you identified and lash at...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
