R
ronfinch
I am looking to put together something that will enable me to accurately control the temperature of water inside a container such as an electric slow cooker, at pretty low temperatures 65 - 70 centigrade.
I am looking to buy the components and fit it together myself simply to save money...
I believe I need the following:
i. Digital PID with SSR output, I obviously need to be able to set the temperature/it needs to display it. A timer and or high and low temperature alert are not essential but would be good. As would maybe be an autotune/self-tuning function for the PID...
ii. Solid state relay of some appropriate power rating. 1 of the sets I saw specified (40A), 24-240V AC. The unit will only be used in the UK I do not know if this affects the Voltage rating I need
iii. A temperature sensor probe - one of the kit specified a PT100 temperature sensor probe with a M8 Fixing Screw, Flexibe Spring and an Armored Wire Cable.
Can anybody help me out with advice as to units I can buy? Haven't been able to get the advice I think I need, am hoping an electrician/someone interested in electronics could help me out here....
Thanks very much if you can.
