J
JS_Electric
If a transformer has 50 turns in the primary winding and 10 turns in the secondary winding, what is the reflective resistance if the secondary load resistance is 250 ?
Discuss need answer in the UK Electrical Forum area at ElectriciansForums.net
Answer c) 6250Ω
Yes, I can. I haven't seen your attempt yet. This forum is not set-up to do you homework for you, however, if you make a genuine attempt and make a mistake we will tell you where you've gone wrong.thanks for reply. Can you explain it?
Reply to need answer in the UK Electrical Forum area at ElectriciansForums.net
