Yesterday, I replaced a light switch (as I've done several times before). When I turned the breaker panel back on, the light was working - but now the other lights connected to that same breaker panel do not work. I re-checked all connections and reset the GFI (the outlet works) but no luck with the other lights. Volt meter confirmed that no power is running into the switchboxes of the downstream switches. Any suggestions appreciated.
