Need for isolating switch | on ElectriciansForums
Discuss Need for isolating switch in the UK Electrical Forum area at ElectriciansForums.net
Should a small 500W electric rad on a fused spur also have an isolating switch?
Some of these small rads have fancy timers that might get confused if switched off at the wall rather than their controls.
They usually do, but don’t know if it’s a requirement.
Does turning the thermostat all the way to minimum turn it off?
Edit:
Actually thinking about recent ones I’ve seen there are no switches on the heaters themselves in a community centre.
Just a thermostat whose dial had been removed to stop public tampering, and an unswitched fuse for power.
Is the heater connected to a ring final ?
Is the heater in a bathroom ?
Reply to Need for isolating switch in the UK Electrical Forum area at ElectriciansForums.net
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
All good thanks, still trying to retire but still finding myself busy as ever. Hope you're well.
