Need help in earthing arrangement | on ElectriciansForums
Discuss Need help in earthing arrangement in the UK Electrical Forum area at ElectriciansForums.net
Hello guys,
hope you all keeping well. I'm new bird on this forums as this is my first post thread. Anyway, one of my customer saying, after every visit from British Gas engineer they always saying 'you don't have suppler earthing in your property. pls sort this out ASAP.'
When i went on site to do initial inspection, I checked main cut out unit. and i can see earth wire coming out from main incomer city cable. Please see my attached picture for your reference.
So why BG engineer keep on saying NO SUPPLER EARTHING? I know the best way to check by performing Ze test, but I'll get my multi meter back after two weeks. And i have to quote him in two days.
If any of you come across with this kind of installation (see picture) and what you did to solve the problem? (earth rod installation, bonding to water n gas pipe, asking energy provider for Ze??) it would be really help full, if I can little bit of advice please. To be honest i never seen installation like this, particular in earthing arrangement.
Many Thanks.
107.
  • [ElectriciansForums.net] Need help in earthing arrangement
What my learned friends said in post 2 and 3.
I'm not too sure what you're on about in that last paragraph when you're talking about an earthrod installation etc, perhaps you could explain. Have you seen an earth rod anywhere on the property?
If you were to phone the DNO and eventually get through to someone who knows or cares what you're talking about you would get confirmation of whether they provide an earth facility or not but the Ze figure they'd give you would just be the maximum allowed in the regs so would be pretty much worthless.
Other than that mate you can't do very much till you get your test gear.
Hello guys,
Many Thanks.
107.
look.....never mind what others are tellin you.....confirm yourself...Ze as trev has said......
anything else is turd....
I had a customer call me after a bg engineer had Serviced the boiler and said that the earth was >100 ohms and this was incorrect and they would sort it, luckily my customer said no and they had their own spark. Anyway went round carried out zs at boiler spur and everything was as it should be. Bloody bg
Reply to Need help in earthing arrangement in the UK Electrical Forum area at ElectriciansForums.net
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
