donkey131
[h=3]Electrical Question? i have a revision question but not sure on how to work this out. Any help please?[/h] An electric furnace is used to melt a brass rod which has a mass of 500kg.
The furnace is rated at 200kW and it is fed from a 440V supply.
The initial temperature of the brass is 6°C and the melting point of brass is 910°C. There is no heat loss from the furnace and the specific heat capacity of brass is 0.39kJ/kg°C. Calculate:
(a) the time it takes to melt the brass;
(b) the furnace heater current.
not sure on how to do the above question any help please.
