need help on what settings to put in a D.O.S starter for a 0.65Kw three phase motor | on ElectriciansForums
Discuss need help on what settings to put in a D.O.S starter for a 0.65Kw three phase motor in the Electrical Tools and Products area at ElectriciansForums.net
A
Aaron1988
if i have got a 0.65Kw three phase motor does anybody know what i need to change thew settings to in the D.O.S starter??
Re: need help on what settings to put in a D.O.S starter for a 0.65Kw three phase mot
the overload on the started should have a dial on it that says Ir. It will have either a percentage of max current raing (so for exmaple 0.8 of In) or it will have exact current ratings. i would turn the starter to max, and then switch it on. measure the current and set the overload to 110% of that reading. Or another method is 110% of the FLA (which is written on the rating plate)
im sure on the dial it goes from .80 up to 1.2, i was told to add about 20% onto the 0.65Kw, so i set it to .80.
is that ok?
i was taught to add 10% and i believe that when a similar thread arose on here, that was the general consensus.
Are you sure on the 0.65KW part...never seen one...0.55 and 0.75KW??
Scratch that just found an Exx proof one.......agree with the 110% FLC
yh im pretty sure its 0.65Kw, its in my AM2 test so they prob trying to mess me about :)
Was the dial preset to the maximum just to make sure you did make adjustments??
yea it was set to the maximum and the assessor said about adjusting it to suit the motor
i haven't got one to hand but i would double check to make sure its not 0.65Kw/60Hz-0.55Kw/50Hz and i think you may have 2 different FLA specs, i may be wrong but i have definitely seen both on the same nameplate many times.
Reply to need help on what settings to put in a D.O.S starter for a 0.65Kw three phase motor in the Electrical Tools and Products area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
I really can't see a problem with it assuming there is a neutral there.
