Need Help Unvented cylinder with one 3 port valve. | on ElectriciansForums
Discuss Need Help Unvented cylinder with one 3 port valve. in the Central Heating Systems area at ElectriciansForums.net
I
Imants
Hi, i have changed my hot water cylinder for a Megaflow hot water cylinder. now having problems to wire this thing in. the programmer i have (Tempus 7) has only got HTG on and DHW on options, so i it's only for 2x2 port valve system?!?! originally i have only 3 port valve at the moment, looking to install additional 2 port for Y system, but then again, it asks for a DHW off option from programmer... really confused now. do i really have to replace the programmer as well, or there is any better ideas. Thanks!
If you running a 3 port you would need it to be sprung return for this to work . So you need to either change the valves or the programmer
You could of course fit a relay to it for it to motor over when off
Reply to Need Help Unvented cylinder with one 3 port valve. in the Central Heating Systems area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
Certainly is!! And another thing .......... On the old Hive receiver the relay common is a separate terminal, whereas on the new Hive presumably...
