Need help with a waxpot | on ElectriciansForums
Discuss Need help with a waxpot in the UK Electrical Forum area at ElectriciansForums.net
steveohim
Hi my wife has a wax pot she uses for her job and has lost the lead, I've found a spare lead but I need to know the size of the fuse that should be in there, she had a spare lead she used before and it melted
This is the only info I have on the waxpot
[ElectriciansForums.net] Need help with a waxpot
Well the fuse is really to protect the lead,so assuming the lead is rated at 10a that will be OK. However in practice it is better to choose the next size fuse up from the load current, which in this case is around one and a half amps.....so ideally a 3a.
Reply to Need help with a waxpot in the UK Electrical Forum area at ElectriciansForums.net
Yes that was me. If you change your mind give me a shout and I’ll sort something out for you 👍
Thanks for your advice bud, I actually spoke to a Gold Card holder over the weekend of whom gave me the same advice
