E
eli
Hi
I need help, im not sure how to answer this type of question. Its a basic circuit design question. ive got a book and it says that these are the eight basic steps in a simplified form.
1. Determine the design current Ib
2. Select the rating of the protection In
3. Select the relevant rating factors (CFs)
4. Divide In by the relevant Cfs to give tabulated cable current carrying capacity It
5. Choose a cable size to suit It
6. Check the voltage drop
7. Check for shock risk constraints
8. Check for thermal constraints
How would you work out each stage?. Any ideas, are there any sample questions just to show working out so i can get a idea.
thanks.
thanks.
