need help with induction hob/double oven dilemma | on ElectriciansForums
Discuss need help with induction hob/double oven dilemma in the UK Electrical Forum area at ElectriciansForums.net
dp2307
Hi everyone, I've been asked by a work colleague of a friend to finish wiring her kitchen as her electrician has done a Houdini!
She is having a indesit double oven rated at 4.8kw and indesit induction hob at 7kw , the previous electrician has wired a 6mm t+e into the kitchen can I use this to supply both appliences via a 45a d/p switch and 45a dual plate outlet? Another point to add Is for an unknown reason he has supplied another 6mm t+e currently coiled up under kitchen floor (possibly for some kind of garage supply) which home owner has said can be used if neccessary. Would appriciate your thoughts and opinions thanks.
dp2307, this has come up so many times now it's getting beyond a joke. If you look at the foot of this page you will find ''Similar Threads''!! If you look at those threads, you will undoubtedly have your answer...
yes. next?
Doctor I've got this itch I cant stop scratching
You should of asked
doctor I have an itch, does the law allow me to scratch it with my existing completely capable hand, or do I need to have a third arm genetically created in a genetics lab, then sewn onto my body in an awkward and nearly useless position, just so I can scratch it?
seems parallel to the cooker questions being asked this week
Reply to need help with induction hob/double oven dilemma in the UK Electrical Forum area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
Hi thanks for the reply, it is definitely 10mm2 as can see it written on the outer. It goes through the roof rafters with no insulation and then...
