Need Help Working Out This Question! | on ElectriciansForums
Discuss Need Help Working Out This Question! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
E
Edwardioo
The Following resistors are connected in series to a 240v supply, 10ohm, 20ohm, 30ohm, calculate to power dissipated in the 10ohm resistor.
How do i do this, and how would i do it for the 20ohm and the 30ohm resistor?
Cheers Ed.
You should firstly always read the question carefully. It doesn't say whether it's an a.c. or d.c. supply. It just states a 240v supply.
The current in the circuit can be worked out from
I = V/R = 240/60 (total resistance in circuit) = 4A
To calculate the power dissipated in the 10 ohm resistor you first need to find the voltage across the resistor. Using Ohm's law again;
V = IR = 4*10 = 40V
Then using P = VI, P = 40*4 = 160W
Upvote 0
The thing to remember is that in a series circuit the current is the same throughout the circuit and the voltage is "shared out" between each component in the circuit.
It's the other way round for parallel circuits.
So for the 20 ohm resistor, we now know the current in the circuit is 4A, so we work out the voltage across the resistor again.
V = IR = 4 x 20 = 80V
Again P = VI = 80 x 4 = 320W
Upvote 0
my way is just as good, the only diff was i used 230v as could not see the question when i was typing the solution. and it don't matter if it's ac or dc as far as resistors are concerned.
Upvote 0
Hmm how was I so far out then?
I used one of the more obscure formulae off the formula wheel.
I never managed to get that thing to work.
OIC - didn't read the question properly.
Upvote 0
Reply to Need Help Working Out This Question! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
As you have actually measured the cold resistance (R1 + Rn = 0.15) then you have the voltage drop at the expected current (60A) so you can compute...
Just doing some thread admin :)
Electrical Courses
