need new switch but where do they go | on ElectriciansForums
Discuss need new switch but where do they go in the UK Electrical Forum area at ElectriciansForums.net
shaz27
lancashire uk
rewired downstairs with help from someone on here , but it’s the top switch that cause the problem,
it seems the wires weren’t screwed in due the terminal screws being knackered, i have a new switch but totally different and plus one of the browns is really short
there is 5 browns 2 black brown sleeve 1 grey brown sleeve , plus a brown bridge connection, i believe i know know where they go in old switch but not the new
  • [ElectriciansForums.net] need new switch but where do they go
L is top
1 is bottom left
2 is bottom right
Reply to need new switch but where do they go in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
So you are good to go. Don't follow the diagram 2 that I posted since that requires the tab to be removed. Instead connect the incoming hot to...
