Hello! I've just joined the forum and am looking for a little advice.
- As what I am attempting to do will never be attached to the electrical grid (and why this is relevant will be obvious in a second) it should bypass any laws around such. (and if it doesn't, I have a licensed mate who will do any installs for me!)
Ok. Onto the problem!
I have a fridge in a caravan. It's a 240V "beer fridge" It's not 240/12V.
I have a 12V > 240V 400-1200W inverter.
It *is* enough to sustain the fridge (it's only a little fridge) but it doesn't have enough Peak power to charge up the compressors capacitor before it trips the inverters breaker.
It is *not* tripping any fuses.
and after resetting the inverters breaker it runs perfectly.
Obviously the time between the resets is giving that compressors capacitor enough juice to start the motor turning, and allowing the fridge to run.
Once the fridge's compressor is working, it works perfectly! Inverter isn't overheating/tripping/etc.
(I just spent an hour testing this.)
Okay!
Here's the question.
Can I build a device that sits between the inverter and the fridge, that will build up a charge slower, as to not trip the inverters breaker, and still allow the fridge to start up?
and not ... do anything untoward. Switch off when the fridges demand drops to "running"
I'm thinking; something like a bank of capacitors? They charge up gradually, and when they hit a certain amount, they dump into the fridge, allowing to get going.
Has anyone ever done anything like this before?
Yes I realise, it would be *far* simpler to just go and BUY an upright 12v-240V But I don't have a spare grand burning a hole in my pocket. I have an inverter I got for practically nothing, and a fridge that was; likewise; nothing.
Ignore the whole "12V" side of things please.
Basically - Can this be done?
Can it be done safely?
Can it be done cheaply (call this budget $100)
Thanks!
Okay!
Thanks!
