Need some help with changing a switch (Europe) | on ElectriciansForums
Discuss Need some help with changing a switch (Europe) in the DIY Electrical Advice area at ElectriciansForums.net
Dilantha
Sweden
Hi,
Im trying to replace a bulb switch but im not sure where to place the wires on the new switch.
First image shows the existing socket and on the second picture the right side socket is the new one that im going to use. Any help would be highly appreciated. Thanks.
  • [ElectriciansForums.net] Need some help with changing a switch (Europe)
The two brown wires connect to L.
The black and white each go to a terminal marked with an arrow.
Reply to Need some help with changing a switch (Europe) in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
