Hi Rajeev
You can't mix landscape and portrait in the same string, they have to be same orintation, same panel, same azimuth and same pitch, so your down to 7 and 6
There should be at least 400 mm from any edge. (ridge / eaves etc)
Is the 7.15 m on the drawing the 'slope length' or the distance from the apex to thebase of the triangle? The other dimensions are clear enough.
Anyway, you'ld get 8 x 190W generics in Landscape on the Rear-South and 7 x 190W generics in Portrait depending upon the actual dimensions
Even Sanyo's don't yield more becasue of the shape, (and they'll cost a lot)
