I am running a power supply wire from my house electrical panel that needs to power a pool pump(9amps) and water fall pump(9 amps) plug in (15 amps) and some simple outdoor lights(15amps). This is 180 feet in one direction. What are your thoughts and advice on this project? all voltage will be 110 and I can run 2 supply lines if that helps out with the load...
Thanks. Josh
Thanks. Josh
