Neff dishwasher Child lock? | on ElectriciansForums
Discuss Neff dishwasher Child lock? in the Electrical Appliances Forum area at ElectriciansForums.net
Buffyrose
Norfolk
Hi, I have an integrated Neff dishwasher - came with house so not sure of age. Probably 15 yrs. All A1 OK but last night I somehow rammed something against the top door catch, there was an ominous click either something clicking aside, or snapping. Now door won’t click / close, so ofcourse dishwasher won’t operate. Eventually, I sat for an hour pushing the door too just to get it to run through it’s programme. There are countless questions re this on the internet with not one helpful reply. The instructions with the dishwasher are useless. I’m sure it’s a child lock, and not snapped. Any ideas? Thanks a bunch as always. ( the first photo is the door on which there are no moving parts, so is irrelevant, just included it for completeness).
  • [ElectriciansForums.net] Neff dishwasher Child lock?
Looks like you've set the child lock with the door open, when it's normally set with the door closed.
Try pushing the latch to the left,[ElectriciansForums.net] Neff dishwasher Child lock? as arrows.
Try pushing the latch to the left,View attachment 64144 as arrows.
Yes, that seems to fit the scenario exactly - and yes, the door was open. I just can’t get that flap to budge - presumably as it’s a lock it’s going to be tough- but I’m hurting my fingers - it’s just solid. It goes up into itself, into the machine but I can shift it R or L.
Does the part on the left of the latch that to me looks like a spring either push in or pull out allowing you to slide the other part across.?
I've scoured the Internet including U tube and can't find any explanation of the child lock.
The best I found was a demonstration of a Neff dishwasher done in a showroom which included the mention of a child lock and they showed it in a bag, to be fitted if required.
Picture two and four look totally different so something is moving and needs re-positioning to latch, the triangular piece latches into the door so need to recess on closing the door and extend to hold the door closed.
It looks as though the child lock is fitted on photo four, not possibly in the correct position, but not fitted on photo two have you removed it?
S51M53X0GB/21 is the E-Nr number that Neff ask for and also comes up on spares sites
Picture 5 has the details on.
Missed that ?‍♂️
Drawn a blank with information about this specific model, but Neff's own site has this advice for door closing issues:
  • Problem category: Malfunction​
    Issue: Door function defective​
Door can't be open or it is difficult to open
Cause​
Childproof lock is activated
Resolution​
Press lever above the door (childproof lock) to the right and open door.
Door does not close properly
Cause​
Door lock is snapped over
Resolution​
Close door with increased force.
Not sure that it's particularly helpful, but does suggest that child lock issue would likely prevent door from opening, rather than closing.
I'm not convinced it's a child lock.
I think that's just the normal lock and it's got itself out of sequence.
The part on the right needs to be up and latched so the door will close.
And the part on the left when pushed back by the door releases the catch, on the right which drops into the hole in the top of the door.
When the handle in the door is pulled the grey part in the top of the door lifts the catch up and latches into the lock.
The solution is the part on the right needs to be pushed back up into the lock until it laches and stays up.
Yes, that sounds and looks a bit like it. The bit on the right seems out of place to me, but I’m using all my might and just can’t budge it - it think it does need to come forward now, and then as you say, normally the bit on the left is the bit that releases it. I honestly didn’t ‘ram’ anything in so I can’t understand why I can’t release it.
Reply to Neff dishwasher Child lock? in the Electrical Appliances Forum area at ElectriciansForums.net
