I have a 12 year old Neff Oven b1442n0gb who's fan element stopped working.
I bought a generic element from amazon (NEFF Fan Oven COOKER ELEMENT 2400w eq2 499003 spares: Amazon.co.uk: Large Appliances - https://www.amazon.co.uk/COOKER-ELEMENT-2400w-499003-spares/dp/B002ZXUV2C/ref=sr_1_1?keywords=2400w+eq2+499003&qid=1572014944&s=appliances&sr=1-1).
The oven has three spade connectors - two with single wires, one with double wire.
After connecting up the new element, RCD tripped when turning the heat on for the fan element (other parts of oven worked fine without tripping - top element, bottom element and fan).
I wasn't 100% sure if I had connected the wires to the correct terminals in the new element so I changed to the two single spades to one terminal and double to the other.
Now fan element is working, but I can't control the temperature - regardless of what I set it to, it just goes to max temperature and light stays on
I guess I should just get the thermostat replaced?
But I'm wondering is it actually something else.
When the fan element went, the thermostat was still working fine with the other elements.
Could it be caused by having a generic fan element even though it has good reviews on amazon?
I'm also unsure if I wired the spades correctly - could that cause an issue with the thermostat or is the fact that the new element heats up proof that it's wired correctly?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
