Hello,
I am about to install NEMA 14-50 outlet to charge other electric car in the garage and I will run 6 gauge(THHN) wires into the 3/4 in. conduit across to other side of the garage. The electrical panel is outside the garage. My questions are
1. Is it okay to use 10 gauge bare copper grounding wire instead of 6 gauge (green) for grounding from the panel to the NEMA 14-50?
2. where can I get the jacket to cover the wires where the wires are inside the wall? It will be only 6-10 inches inside the wall?
Thank you,
Thank you,
