Hi all im looking for some guidance please.
i dont have much experience with heating systems but done plenty of domestic. This is my own house and here is what i have:
ideal logic 35 (logic not logic plus)
danfoss tp5000 stats x2
2 zone valves
nest 3rd gen kit
im aware a nest is needed for each zone and ill buy another but for the minute, the second zone runs one radiator only in one room. im going to consider doubling it up into one until i have money for the second nest in a few months.
right so its a new build with feed to boiler spur and 5 core into boiler. the boiler has mains voltage on the thermostat connections and i have installed my heatlink via a 5 core and done the mains power plus the opentherm connection. nest all operational at this point.
The danfoss 5000's have a 3 core to each from wiring centre and i understand most of the system wiring. 4 cores into valves. stats are wired as n/o contacts.
im having issues figuring how to go about removing the old stats and powering the nest when i wall mount it. its currently via usb.
the stats have mains switching for the valves as does the boiler on the stat connections.
please can anyone shed some light? i think the nest may not be operating correctly and calling for heat because of the existing stats. i know they need to go eventually but i just wanted to test at this point. i think the stats are holding it off calling for heat.
im i right in thinking remove the 3 cores from wiring centre to stats if not needed and connect valve switch wires to permenant feed to keep them open?
im just lost as to how to get low voltage at wall for nest and mains at valves
thanks for bearing with my waffle and i really appreciate any help
2 zone valves
nest 3rd gen kit
