hi guys I’m thinking of future prodding my lighting circuit if I ever want to go for smart switches. I understand I’ll need a 35mm back box and I believe a neutral is required at the switch. I’m and running a new circuit in my house for it and would prefer to run the feeds in and out at the switches however this won’t be able to be achieved as the conduit to light switches will only fit on cable and I don’t want to damage the walls/plaster. I was thinking of running a 3 core cable from ceiling rose to light switch (live feed, switched live and connect neutral) and just leave the neutral connected to a choc block in light switch for if I ever go for smart light switches. Is this deemed ok to do leaving a floating neutral?
