Susan Gillespie
gas engineer can't fit new heating programmer as I need a neutral connection on the back plate. Advised to get an electrician. How much would this cost or would it be better getting a new heating system?
Discuss Neutral connection to heating programmer in the UK Electrical Forum area at ElectriciansForums.net
What programmer is in place already?gas engineer can't fit new heating programmer as I need a neutral connection on the back plate. Advised to get an electrician. How much would this cost or would it be better getting a new heating system?
3 light years ,strima.How far is the programmer from the heating system, power supply et
you need to get an electrician have a look at it. a quote should cost nothing, and he/she can advise on what you need and the cost thereof.gas engineer can't fit new heating programmer as I need a neutral connection on the back plate. Advised to get an electrician. How much would this cost or would it be better getting a new heating system?
and ask him to bring a ball of string to measure out the cable that needed.you need to get an electrician have a look at it. a quote should cost nothing, and he/she can advise on what you need and the cost thereof.
Reply to Neutral connection to heating programmer in the UK Electrical Forum area at ElectriciansForums.net
