Neutral earth crossover | on ElectriciansForums
Discuss Neutral earth crossover in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just imagine if the main earth became disconected, everything that has been bonded , rads, pipes,Taps, sinks, metalwork could be at mains potential with no rcd to protect you ( a bit (LOT) dangerous me thinks)
why would you want to connect a N to the earth bar?
Paul
Reply to Neutral earth crossover in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
If you are testing you can link the suspected 'neutral' to the chassis/earth with something like a 100 watt mains filament lightbulb. If the bulb...
