Neutral earth fault | on ElectriciansForums
Discuss Neutral earth fault in the Australia area at ElectriciansForums.net
H
Hodgie
Hav neutral earth fault on fire alarm loop all heads r on understand about halfing n quartering but wonder wat tester to use wat setting n wot results will tell me
are there any call points on the circuit . do not do an insulation test unless you 100% there is nothing
connected. try removing all heads . and test each lenth of the cicuit with low ohms test meter.
12 volt equipment will not survive an insulation test
do a resistance test if you reading around 470 ohms your reading the resistor
Reply to Neutral earth fault in the Australia area at ElectriciansForums.net
