neutral earth short on incoming tt supply | on ElectriciansForums
Discuss neutral earth short on incoming tt supply in the Australia area at ElectriciansForums.net
hoover
While tracing a unrelated fault in my own house i discovered that there is a dead short between the neutral conductor on the suppliers side and the earth which i've supplied through a spike. The house supply is took from a transformer on a pole in my back garden. Cant get my head roungd it. Is there a problem on the suppliers side or is there something more obvious? Im aware you would find this problem in a tncs supply but a tt?
The N of the transformer will be connected to an electrode there, so the impedance between N and E will only be the distance between your electrode and the transformer pole. In the past I've noticed that a lot of TT supplies have been changed to TN-C-S
As Marc says earth and neutral are the same thing on the supply side
Reply to neutral earth short on incoming tt supply in the Australia area at ElectriciansForums.net
Hi Mainline and thanks for the reply. My inverter is only fed from the mains supply over a 4 hour period at night and it does not have any tie...
