L
LeeCage
This question is mainly for academic interest - my neon screwdriver isn't rated for 11kV
A colleague recently asked about neutral earthing so I explained all about TT, TN, -C, -S, -C-S, etc. Shortly afterwards, I happened to be staying at a place fed by overhead power lines, so, perfect opportunity to look at a "real-life" installation. (Yes, some of us do lead very sad lives
Incoming 3-phase 11kV, feed down to transformer - check.
4 LV terminals, labelled a2, b2, c2 and yn for the lives and neutral - check. Earth wire coming up the pole, connected to the casing and other metal parts - check. (Interestingly, the barbed wire wasn't earthed, guess people deserve what they get if they climb that far).
Then, on the LV side, 5 wires running off to feed the handful of local houses, each fed from a live selected from L1, L2 or L3 plus N & E - check.
But, hang on. No apparent connection between N & E anywhere. I traced the wires very carefully and have photos to prove it! [Now just waiting for the knock on the door from MI5]
So, to the question(s). I presume this isn't IT? Is there a connection, maybe high impedance, inside the transformer casing? Is it relying on distributed conductor to E impedance? Or what?
Hope someone can explain before I drive into a hedge craning my neck to squint at every transformer that I pass.
