M
m4fiaafg
please can anyon tell me do three phase motors have or have not got neutral, please if you can for star and delta thanks
Discuss neutral on three phase motors in the Electrician Talk | All Countries area at ElectriciansForums.net
please can you talk abit more on it, i was told something about balanced loads or some thing along those lines, cheers
I smell an essay question or two, if so having others spin out the answers for you will not help you learn, it will only hold you back when you are out on the field doing the work where this understanding is necessary.
If these are just genuine inquisitive questions then ignore this post and keep up the good interest in the subject, it was just the 'as much detail as possible' makes it sound like revision and if you had already studied it you should only need a reminder not a detailed answer.
Reply to neutral on three phase motors in the Electrician Talk | All Countries area at ElectriciansForums.net
