M
mountainman
Hi all, I need a new consumer to fit in a small area approximately 345mm wide that will house
Sent from my SM-J500FN using Tapatalk
Discuss New 17th edition mcb in the UK Electrical Forum area at ElectriciansForums.net
sounds like hs'e had mroe to dirnk thna waht i have.Sounds like you need a skeleton board for a mantel unit. But I may be wrong.
Yes Murdoch , I am predominantly a gasman. I am also part P full scope so I could do the job but don't have the test kit anymore.Best you look at rcbo boards then.
Edit. So you are a gas man, so get a decent spark involved
I have a spark to do the job but he is more familiar with standard boards.
If I can find one that will fit the available space then life would be easier.
Reply to New 17th edition mcb in the UK Electrical Forum area at ElectriciansForums.net
