New bonding methods, what do you think? | on ElectriciansForums
Discuss New bonding methods, what do you think? in the UK Electrical Forum area at ElectriciansForums.net
Most water pipes feeding a property are now plastic, but anyways I have connected up the unused flux capacitor from my broken down DeLorean to the plumbing just to be over cautious, it works as a waste disposer as well.
Quote "the magnetic fields caused by plumbing currents are then mitigated" . Fantastic ! I thought magnetic fields were caused by electric currents (etc) and not water movement in pipes ... must have slept through that bit o_O
Assume there must be an issue with DNO means of earthing and/or a fault in his house to create this field?
Reply to New bonding methods, what do you think? in the UK Electrical Forum area at ElectriciansForums.net
To the OP, I would ask the sparky to measure the "Ze" using the neutral and a phase. If it comes out low at 0.35ohm or so, then ask the utility...
Although the gas pipe may no longer require the bonding, it should really be terminated correctly or completely disconnected at the other end...
