T
tom79bmth
Hi haven't done new build for a while last time I done one it was 25 % low energy and fitting could only use low energy lamps, I know it's 75 % and I think you can use normal fitting as long as a low energy lamp is fitted
My questions is if I fit a gu10 downlights what led lamp can be used I don't quite understand the 40 lumens per watt thing
Many thanks
Many thanks
