New Build Development Pricing? | on ElectriciansForums
Discuss New Build Development Pricing? in the UK Electrical Forum area at ElectriciansForums.net
N
nlbhoy
I'm looking for some help/guidance with the prices I've put together for a new build development
of 30 houses, I've not yet submitted my bid as I'm looking for some constructive feedback from
anyone who has experience pricing this type of work.
Job is based in Scotland.
I've not had much experience pricing this type of work.
Houses are typical 3 and 4 bed semi's, nothing fancy.
3 bed has around:
23 sockets
8 tv/bt points
3 fans
11 switches
11 pendants
5 smokies/heat
cooker
heating/combi boiler
Main board + testing
gas bonding
mains door bell
I've priced it up per point @
ÂŁ40 per socket/bt/tv
ÂŁ100 per fan
ÂŁ25 per switch
ÂŁ25 per pendant
ÂŁ80 per smoke detector
ÂŁ125 cooker
ÂŁ150 heating
ÂŁ300 main board + testing
These prices per point are cheaper than I would usually charge doing extensions/ conversions etc
total price came to about ÂŁ3500 for the 3 bed semi. I estimated around ÂŁ1500 for materials and ÂŁ800 labour. After the 5% retention and 2.5% main contractor discount there would be approx ÂŁ800-900 profit, not including overhead which is minimal.
Is this to cheap? I would like to get the job as it's around 18months of work, but on the flip side
I would also like to make some money from this.
looks pretty good to me. I mainly do new builds and from the info you've given based on a 3bed semi my price would be roughly ÂŁ3600. you don't have any external lighting? For that price I wouldn't be providing/installing an aerial.
Yeah, there are 2 external lights, I priced them around ÂŁ90 each. They were in the total price but I forgot
to add them on the list above.
I'm not supplying/installing an aerial, just running them to the loft and making ends off.
There is a sure stop switch and the wiring of a future shower that I also forgot to put above, but are in the total price.
I worked it out based on the info at the time and come just shy of 3.3K then put 10% on top of the whole lot and come to ÂŁ3.6K. With two external lights and a shower supply I would be more around 3.8K. Being in the south though does mean my prices will normally be a little higher.
Your price is about the same as ours would be. We lost out on 5 x 3bed semi-detached with a similar spec last month. The firm that won them are doing them for ÂŁ2250.00 each!
That's because they use unskilled workers and some poor QS has to sign it off.
There's a 300 house estate going up near me and what I can see is not good, so what is hidden behind the plaster board?
I've just been out on site to visit a spark (regarding a different job) But he was on a new build estate, around 30-40 houses, There was 4 fully qualified sparks, and the rest were just agency supplied mates, Some with no experience at all. The electrical company won the contract due to them being thousands cheaper than any other, But the sparks on site are tearing their hair out having to try and work with all the agency lads as well as actually get things done to a decent standard. Recipe for disaster if you ask me.
Reply to New Build Development Pricing? in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
T
New plumbing & heating system advice Hello, I'm installing a new central heating & plumbing system and just wanted to run through my design...
tommyh311
T
