B
BoocockP
Hi all,
I'm due to install a mains supply to a new house. Whilst the original house was demolished we paid YEDL to relocate the meter box to a stable block building with the veiw that it could stay there to prevent having to fork out again to have it moved back to the new build. The supply fuse is 80A and we plan to run a 25mm/35mm SWA from the meter box to the utility room in the new house which is approx. 50 metres. This will be terminated in a 63A fused switch isolator and then 25mm meter tails into a split load CU. We then want to run another 16mm 40A sub main from this CU to an annex within the same new build which will terminate in a smaller CU. Can anyone see any problems with this design?
Any advise will be gladly accepted.
Paul.
Paul.
