New circuits into plastic consumer unit | on ElectriciansForums
Discuss New circuits into plastic consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Whitehaven
Morning everyone . Question regarding wiring of new circuits into plastic cu . I’m wiring an extension on a property soon . The consumer unit is under the stairs and it’s plastic it’s all rcbo Wylex board in good condition with a few spare ways . Probably the last of its generation before we moved into metal boards . My question is can I add 3 new circuits and surge protection to the board and still comply with regs . I cant find a definet answer in the regs book . Wondering if anyone else has had this scenario .
If the CU is is good condition with no signs of thermal damage then I would just make a note on the Installation Certificate that you have advised the client about the change regarding Plastic Consumer units since it is located under the stairs. I would do this on Comments on Existing Installation.
I would do this just to cover yourself.
As competent persons if we see anything that may require attention we are supposed to report it to the duty holder.
Thanks . I was thinking similar to what you’ve said 👍
Reply to New circuits into plastic consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
