T
Torpediniforme
Rather than have a temporary building supply my customer has agreed with Southern Electricity for them to cut and extend his current supply to a cabin at the rear of his house which is being demolished.
I am planning on installing a small CU with 30mA RCD main switch and an earth stake since there will be no gas or water to bond to, my thinking for this is so that it can also meet the requirements of a TT site supply and also for if it is fed from the CU in the new house in the future. It’s a partial self build project which could take a long time.
Re: the buried earthing conductor to the stake (a 5/8 1200), after looking at the Regs and GN’s 1 and 8, I'm a little confused but assume I need 16mm2 (even with mechanical and corrosion protection)?
My customer will install a surface mounted meter box on the front of his cabin.
Just wanted confirmation that this was the best way or not?! (Originally I was going to install a split load CU with 2 RCD’s instead of on the main switch and an earth stake)
It’s currently TNS. I’m also wondering if Southern Electric will change it to TNCS.
