T
tickover
Hi All!
Could do with some advise please...
I need to replace my old 4 way Wylex fuse board (BS 3036 rewireable fuses), now I don’t have much room so I need a small unit to run 1 x Ring (sockets 32A), 1 x lights (6A), 1 x shower (20A) 1 x cooker (32A) and I am looking at adding power to my brick shed, so I would need one more 16A MCB (Only to run one socket and light with one outside light, will be adding a garage CU withh 1x 6A for lights, 1x16A for 1 double socket, and the incoming switch as a RCD (one of these) in the shed).
It is a TNS installation. So to keep in with regs DO I NEED to install a split board (for 17th Edition) or can I install a 8 way Wylex CU and change the 100A main switch for a 80A/100A 2 pole Main RCD as the main switch as I am upgrading/altering an existing installation.
The property is only a small terraced cottage 1x Bedroom, 1x Bathroom, 1x Kitchen, 1x lounge, 1x basement.
My plan is to use this towards my Part P registration so I want to make sure that what I am proposing to do will be ok.
What else would I need for the assesment...
The shed will be a complete new circuit so will need to do a separate EIC for that and one for the consumer unit but any advise, suggestions etc. much appreciated.
Cheers guys
Tickover
Cheers guys
Tickover
