I've just swapped out an old consumer unit for a new one - like for like in terms of circuits.
One lighting circuit will not set.
I've disconnected the earth on that circuit and it still won't set so I would appear to have a live-nuteral short.
However I did nothing to that circuit at all during the change over.
I've tried connecting the circuit to a different Rcd it still won't set.
I have also examined the cable at the Unit to check it's not been damaged.
What 'stupid' might I have done?
Is it an mcb or rcd tripping? Is there a crossed neutral between the lighting circuits? Also, if your not an electrician are you sure this is work you should be undertaking and what are your means of testing it
Without trying to sound rude I really hope you are an electrician becuase this aint even funny, any dangers could be shouting out if you didnt know what you were doing.
Where are you situated Mate, someone close to you may be able to take a look.
forgotten to test? What test equipment have you used?
presumably the MCB tripping since you mention possible LN short.
have you removed all loads (bulbs) and disconnected L and N but not cpc and tested between each two of the three?
If you had done that you might know more.
There was a not so recent case of installers not doing any testing and "blowing" away the faults by turning on the MCB repeatedly. Then it had left in a dangerous state which later caused a fatality. So just think about what you are doing and whether you can test properly (not just carry on until the MCBs stay in)
only you can answer that ,next .
uk
New consumer unit -I think I've done a very simple 'stupid' - help please.
DIY Electrical Advice
mikeymix,
buzzlightyear,
