daver
Hi guys
Dont know whether this should be here or in general but I'm sure mods will move it.
Friend of mine has numerous flats. He asked me to do a consumer unit change at one of them and make sure it was electrically safe.
I did a mini PIR, IR on all cabling R1 & R2 and checked all was good with the exception of the main earth to gas.
This was a 4mm buried in the fabric of the building going to what I would describe as an out house. The gas is capped off just above the meter. No earth clamp, but continuity shows that the cable next to meter is the 4mm in the C/U area.
As there is no gas in the flat I made a note on the PIR. The landlord also expressed that he did not want the fabric of the building destroyed to put a new 10mm in. (It can be done, but would be messy and I would have to conduit it around 2 walls of the flat.
Then came the curve ball.
When he gets tennants, they can apply for a grant to get a new boiler. So in the near future, the gas may be recommisioned.
So after all that, what is best to cover myself.
Do I remove the 4mm so it cannot be used by boiler fitters.
Do I convince the landlord to put the 10mm in now.
Or will the boiler fitters be responsible to upgrade the 4mm to 10mm.
I am back next week to commision and PIR, so will the note in my observations be adequate for what may happen in the future.
Thanks for your help
DaveR
DaveR
