Evening all,
Not a qualified spark so I thought it better to ask than make assumptions.
Swapping all switches/sockets in our house to screwless ones, all going fine until I went to swap the cooker isolator switch. The old one has feed top, load bottom. The new one has load top, feed bottom. As such, the wires won't reach their intended terminals, and there is no way of reconfiguring the switch assembly to reverse it internally and leave the "on/off" the right way round on the front.
I'm pretty sure the obvious answer is to extend the cabling in the back box, but wanted to check the best way to do this. Can I just crimp and shrink using any suitably rated crimps?
Thanks in advance
Thanks in advance
