M
MattyKHZ
Following a new kitchen installation I find that the current Wylex NHRS4504 CU fitted does not have any spares so need to replace this and ideally would like to do so with another Wylex CU.
It currently has MCB: NSB06 x 3, NSB16 x 1, NSB32 x 4, NSB40 x 1 and a RCD 80A x 1.
So I would like to ask, do I go for another Split Load CU with more ways, or go for a High Integrity Dual RCD, or a Dual RCD Split Load? And is it better to go for RCBO’s instead of the current MCB’s used.
Also by looking it seems some places sell complete CU and others the outer only which I presume would mean I could re-use my old mCB if it is not essential to go for RCBO’s?
And lastly, when PV was installed and I wanted to replace CU then but they did not meet this and just stuck a seperate 2 way up with all the PV isolator and meter, I was wondering if there is a neater solution to house it all in 1 unit. I saw that Wylex did a CU with meter etc built in but the installer was reluctant to use this.
Hope someone may be able to help before I get quotes.
